Hi Guys,
I wrote a code on python with scapy and would like the result to exit with a 0,1 or 2. The problem is that the values are in Date:Hours:Mins:Second which I would like to convert to just one integer value. Can anyone suggest how to convert this to this one int value?
Exit Codes For Passive Checks
sreinhardt
- -fno-stack-protector
Re: Exit Codes For Passive Checks
How about using unix timestamps? Or are you specifically looking to keep it in a more readable form?
