nagios monitoring a failover process
chrislewis28
Post by chrislewis28 »
We have a service which runs in a failover mode and I would like Nagios to monitor it. The logic would be:
check if process is running on host A if yes return OK status, if no check if process is running on host B if yes return OK status if no return critical status.
Is there a way Nagios can do this without me having to write my own plugin?
Chris
gshergill
Re: nagios monitoring a failover process
Post by gshergill »
Hi chrislewis28,
I think you may be looking for service dependency.
Check these links, they should provide you with the details.
http://nagios.sourceforge.net/docs/3_0/ ... dependency
http://nagios.sourceforge.net/docs/3_0/ ... ncies.html
Good luck!
Kind Regards,
Gary Shergill
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I would agree, that service dependencies may be one way to do it, however it sounds like you could write a script that takes both hosts and the service to check. Checks the first provided, if off, checks the second host, if both are off fails critical. Off hand I do not know of a check that does this, but with more information regarding what this service is maybe we can find something.
