Upgraded nagios to Nagios XI 2012R2.3
rdhall01
Post by rdhall01 »
After running upgrade I now see the following issue
XI System Component Status
Event manager red exclamation point
only thing with an issue that I can see How can this be resolved
abrist
Red Shirt
Re: Upgraded nagios to Nagios XI 2012R2.3
Post by abrist »
The event manager should be run from a cron. First, lets restart crond:
service crond stop
ps -aef | grep cron
Check for any other crons still running, and kill them by proc ID:
kill <process id>
Then restart cron and check for eventman:
service crond start
ps -aef | grep eventman
If it is still not starting, check the crontab:
grep eventman /etc/cron.d/nagiosxi
Also, check the eventman.log for any errors:
tail /usr/local/nagiosxi/var/eventman.log
Finally, check the permissions on the eventman php file:
ls -la /usr/local/nagiosxi/cron/eventman.php
rdhall01
Post by rdhall01 »
nagiosxi]# tail /usr/local/nagiosxi/var/eventman.log
C:\ - total: 16.00 Gb - used: 14.50 Gb (91%) - free 1.50 Gb (9%)
Date/Time: 2013-09-05 18:05:02
Respond: https://nagios.saas.infor.com/nagiosxi/ ... 908a939102
Nagios URL: https://nagios.saas.infor.com/nagiosxi/
PHP Fatal error: Call to undefined function mb_convert_encoding() in /usr/local/nagiosxi/html/includes/utils-email.inc.php on line 79
-rwxr-xr-x 1 nagios nagios 4275 Sep 5 13:24 /usr/loc
I also noticed that creating a new user and having it send the email generates a 500 error not sure if its related to the first or not
moved to support ticket
