Anyone, can you give me a solution on this error:
ESX3 CRITICAL - Illegal division by zero at /usr/local/nagios/libexec/check_esx3.pl line 1065
Thanks.
Monitoring FreeNAS
Re: Monitoring FreeNAS
Are you monitoring a volume that does not exist? The line in question references freespace. We have seen this error before and it is usually due to the volume not existing.
Also, you mention that this is a freeNAS device. check_esx3.pl is a script for checking vmware hosts/guests, not freeNAS. Are you sure you are monitoring a freeNAS device? If so, what is your reasoning for using check_esx3.pl?
my $value2 = simplify_number(convert_number($store->info->freeSpace) / convert_number($store->summary->capacity) * 100);Former Nagios employee
