Upgrade trouble Nagios 3.5.1 to 4.0.0
altidude
Post by altidude »
I tried upgrading my Nagios 3.5.1 installation to 4.0.0 today and Nagios will not start. This is on a CentOS 6.4 32 bit system.
I upgraded to 4.0.0 using the instructions at http://nagios.sourceforge.net/docs/3_0/upgrading.html .
When I try to start Nagios it fails with the following lines in the nagios.log file:
[1379959345] Error: Could not load module '/usr/local/lib/mk-livestatus/livestatus.o' -> /usr/local/lib/mk-livestatus/livestatus.o: undefined symbol: last_command_check
[1379959345] Error: Failed to load module '/usr/local/lib/mk-livestatus/livestatus.o'.
[1379959345] Error: Module loading failed. Aborting.
All my .cfg files check out as OK prior to my attempt to start Nagios.
I've rolled back to 3.5.1. Any ideas on how I can resolve this?
Thanks!
abrist
Red Shirt
Re: Upgrade trouble Nagios 3.5.1 to 4.0.0
Post by abrist »
Are you using livestatus? If so, you may need to disable it until the mk devs update it to support core 4.
altidude
Post by altidude »
abrist wrote:Are you using livestatus? If so, you may need to disable it until the mk devs update it to support core 4.
Thanks. I've disabled livestatus for now. Nagios 4.0.0 is working for me now.
Sounds good.
PeterC
Post by PeterC »
Thanks for that. Very helpful
I could not remember where Check_mk was and now to disable it. I found it after half hour.
So to help and save time, # out the following lines in nagio.cfg (On my system it's here - /usr/local/nagios/etc).
# Load Livestatus Module
#broker_module=/usr/lib/check_mk/livestatus.o /usr/local/nagios/var/rw/live
#event_broker_options=-1
Post by slansing »
Excellent, I'm not sure when they will patch livestatus up to function with core 4 but I guess you'd need to watch their site.
