Re: [Nagios-devel] several host notifications for 1 host
------=_NextPart_000_005C_01C79D25.7EFE3C10
Content-Type: text/plain;
charset="us-ascii"
> -----Original Message-----
> From: [email protected] [mailto:nagios-devel-
> [email protected]] On Behalf Of Joerg Linge
> Sent: May 23, 2007 9:24
> To: Nagios Developers List
> Subject: Re: [Nagios-devel] several host notifications for 1 host
> Am Mittwoch, 23. Mai 2007 14:55 schrieb Markus Blum:
> > Hello,
> > i get several notifications after a host went down even
> notification_interval is defined as 0. It seems to be related to service
> checks on these host because other hosts, without service checks, work
> fine. I know service checks will cause a host check but even then there
> shouldn't be a notification before the host check returns a hard state,
> right ?
> Hi Markus,
> i think you are talking about Nagios 3.0a4 right ?
> The same Situation on my system running nagios 3.0a4 CVS 2007-05-23
> Host Down Notifications are sent on HARD and SOFT states.
According to Nagios documentation both 2.x and 3.x:
notification_interval: This directive is used to define the number of "time
units" to wait before re-notifying a contact that this server is still down
or unreachable. Unless you've changed the interval_length directive from the
default value of 60, this number will mean minutes. If you set this value to
0, Nagios will not re-notify contacts about problems for this host - only
one problem notification will be sent out.
Looks like this is a bug... Does it keep notifying after in enters a HARD
state? If no, then setting "max_check_attempts 1" will fix your problem.
SOFT states on service check failures are sending notifications anyways.
Thomas
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"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...[email truncated]...
