Hendrik Baecker wrote:
> Hi List, hi Ethan,
> after playing lots with perfdata commands and so on....
> There is a small (I guess) copy & paste error in xdata/xpddefault.c.
> ######## FIX #########
> diff -Naur nagios3-clean/xdata/xpddefault.c nagios3/xdata/xpddefault.c
> --- nagios3-clean/xdata/xpddefault.c 2007-02-24 12:09:22.000000000 +0100
> +++ nagios3/xdata/xpddefault.c 2007-03-01 14:23:16.000000000 +0100
> @@ -297,7 +297,7 @@
> /* save the command pointer for later */
> xpddefault_host_perfdata_file_processing_command_ptr=temp_command;
> xpddefault_service_perfdata_file_processing_command_ptr=temp_command;
> /* periodically process the host perfdata file */
> Kind Regards,
> Hendrik
Thanks Hendrik! Patch will be in CVS shortly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
