Yes, and haven't resolved it or tracked down the cause yet. Always the
CGI's segfaulting randomly. Mine started in b4 also (IIRC), though
perhaps it was b2... I've got some unresolved posts in the archives.
There are some well-documented causes/fixes for this, none of which were
my issue. If you haven't already, you might want to check the
archives/google/FAQ.
What is your arch and compiler? Does it recur in the same scenario, is
it repeatable, or random?
/eli
Alessandro Ren wrote:
> Helllo,
> I've some servers running nagios, one is running nagios 2.2 and in this
> server, a get a internal server error from time to time in the
> status.cgi while it is refreshing.
> In the others, that run nagios 2.0b4, this naver happened.
> I wonder if someone is having the same problem?
> Thanks.
> __________________________________________________
> *Alessandro Ren*
> /*OpServices*/
> /*Luciana de Abreu, 471 - Sala 403*/
> /*Porto Alegre, RS - CEP 90570-060*/
> *(* phone 55(51)3061-3588
> *4* fax 55(51)3061-3588
> *Q* mobile 55(51)8151-8212
> *:* email [email protected]
