Hash: SHA1
On 11/11/07 03:38 AM, Wolfgang Barth wrote:
> Hi Ethan,
> as with nagios-plugins-1.4.10, check_cluster uses the same command line
> interface as check_cluster2 from ./contrib in earlier versions.
> So, if check_cluster2 is renamed to check_cluster and will be regularly
> installed, your documentation (cluster.html) did not match.
> Ton, can you confirm this?
Good catch! Although we enhanced the official check_cluster (Support
thresholds ranges among others) it's fully backwards-compatible.
Ethan please update the doc
distribution appeared at release-1.4.9.
http://nagios.sourceforge.net/docs/2_0/clusters.html
http://nagios.sourceforge.net/docs/3_0/clusters.html
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHNxic6dZ+Kt5BchYRAoMqAKCxkv0ZwUCr2FnIbfnqVKBDZZoUvQCgqYMa
aQa+BvgcDsMvonB56x+V/v0=
=zOB2
-----END PGP SIGNATURE-----
