Re: [Nagios-devel] Nagios retries checks too soon.
On 06/09/2011 03:43 PM, Paul M. Dubuc wrote:
> Running Nagios 3.2.3, here is an example from the log that shows Nagios
> retrying a failed check after only 10 seconds. The normal check interval is
> 7.5 minutes, retry interval is 1 minute, max. check attempts is 3.
> Note that this test has a timeout of 130 seconds, so it's been running for
> over 2 minutes when it times out. Does Nagios do retries sooner when the
> timeout for a check is longer than the retry interval? Is the retry interval
> measured from the time the previous check starts, or from the time it ends?
I'm not sure. I'm also not sure which behaviour is intended. Arguably, either
is correct and Nagios is doing one of two right things.
OP5 AB www.op5.se
on peace.
