I had some problems with command/service-definitions which use quotes.=20
example: check_command check_something!"--param1 --param2"
Please don't forget to add single and double quotes to the list of =
special
characters.
if(!strpbrk(processed_command,"!$^&*()~[]|{};?`'\"")){
Gerhard=20
> -----Urspr=FCngliche Nachricht-----
> Von: Matthieu Kermagoret [mailto:[email protected]]=20
> Gesendet: Mittwoch, 29. September 2010 13:37
> An: Nagios Developers List
> Betreff: Re: [Nagios-devel] Do not launch a shell for each check
>=20
> On Tue, Jun 1, 2010 at 3:49 PM, Matthieu Kermagoret=20
> wrote:
> > The patch I propose, handle simple commands with shell=20
> quoting (simple=20
> > and double quote). Every command containing any of these characters=20
> > (escaped or not) will be handled by the shell --> !$^&*()~[]|{};?`
> > So any feedback on this new proposal ?
>=20
> Could it somehow make it into HEAD ? It would resolve issue #86.
>=20
> Best regards,
>=20
> Matthieu KERMAGORET | D=E9veloppeur
>=20
> [email protected]
>=20
> MERETHIS est =E9diteur du logiciel Centreon.
>=20
> Start uncovering the many advantages of virtual appliances=20
> and start using them to simplify application deployment and=20
> accelerate your shift to cloud computing.
> http://p.sf.net/sfu/novell-sfdev2dev
> Nagios-devel mailing list
> [email protected]
>=20
