Re: [Nagios-devel] Nagios external commands (2)
------=_Part_20323_14274152.1190620992162
Content-Type: text/plain; charset=UTF-8
Content-Disposition: inline
Hi list,
here is the whole file with all commands actually known. There have
also been some typos which are fixed now.
A little documentation to the contents of this file:
- externalcommands is the root element
- externalcommand is a command like add, remove, disable
- item is something the command operates on, like comment, check, program
- specification describes the interface of a specific Nagios external
command, it has a scope, e.g. host, service, global, all_beyond_host,
and an alias.
- some scope attributes need a further attribute called context, this
could be host, service or nagios
- version is set to Nagios versions supporting this Nagios external command
- options are names and types for options for this command
- usage describes if an option is mandatory or optional
Any comments greatly appreciated.
Tobias
Content-Type: text/xml; name="nagios-externalcommands.xml"
Content-Disposition: attachment; filename="nagios-externalcommands.xml"
X-Attachment-Id: f_f6yosgtq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...[email truncated]...
