[Nagios-devel] Nagios::Cmd version 0.04
I put a new release of Nagios::Cmd up on CPAN. This one should have
fixed most of the outstanding bugs. It can be found at
http://www.cpan.org/authors/id/T/TO/TOBEYA/ or installed with "perl
-MCPAN -e 'install Nagios::Cmd'". Version 0.05 will probably follow on
closely as it will add compatibility with Nagios::Object.
Notable change between 0.01 and 0.04:
* improved test script
* added new_anyfile constructor which can submit commands to
any type of file (i.e. /dev/null or a flat text file).
* added service_check() and host_check() aliases for submitting
passive service/host checks (passive host checks will be in
Nagios 2.0 unless Ethan changed his mind).
* fixed reported bugs
Please send all bug reports directly to me at this address, or the one
listed in the POD of the module.
-Al Tobey
** ** ** PRIVILEGED AND CONFIDENTIAL ** ** **
This email transmission contains privileged and confidential information
intended only for the use of the individual or entity named above. Any
unauthorized review, use, disclosure or distribution is prohibited and
may be a violation of law. If you are not the intended recipient or a
person responsible for delivering this message to an intended recipient,
please delete the email and immediately notify the sender via the email
return address or mailto:[email protected]. Thank you.
