------_=_NextPart_001_01C95AB4.42E19AC3
Content-Type: text/plain;
charset="iso-8859-1"
Hello list,
> Umm. Are you *monitoring* 1000 machines or are you using 1000 machines =
to do
> the monitoring? Just curious..
We are monitoring some 1000 systems (POS-Systems in a german Drugstore)
> Besides that, why not use lzo instead? It's a lot faster (although it =
doesn't
> compress as well), and it comes with a minilzo.c that can easily be =
included
> into the sources for those platforms where the zlib header files =
aren't
> installed.
I did not knew about it, i will have a look at it.
> What did I do?
>=20
> To make ndomod.c more readable, I refactored some of its
> functionality.
>=20
> First, I moved the option-parsing to extra files parseopt.[c|h]=20
> parseopt.h defines a struct to hold all configuration data for
> ndomod, replacing various global variables in ndomod.c. parseopt.c
> does the option-parsing with parameters given by nagios and the
> configuration file. It also contains the default values, formerly
> kept in ndomod.c.
This sounds like a worthy change in its own right, imo.
It should probably have been a patch of its own. I'll see what I
can make of it.
Fortunate, I have intermediate copies of my work. I will copy ndoutils =
with only this change this evening at =
http://joey.in-ulm.de/2008/ndoutils
> > I also [..]
> > I patched [..]
> > Finally [..]
>=20
> I'll say it again: minilzo.c would have been a ton better for you :-/
> Since this is intended to be a performance booster, I'd like to see
> some real numbers on what the performance was before and how this
> patch changes it. If it's major code-surgery for a 10% increase, I
> think it's safe to say it'll be dropped on the floor, but if it ups
> performance by several orders of magnitude, I'd be very interested
> to work on it. Either way, some real numbers, please.
I'll try to gather some numbers.
> I tried to build a .diff-file, but I doubt the attached file is
> really usefull. I published the whole changed ndoutils at
> http://joey.in-ulm.de/2008/ndoutils Please have a look at it.
>=20
> It looks ok-ish, although far too large. I wish you'd have made
> several different patches of it so that each independant step
> could be reviewed and tested for correctness. As it stands now,
> it's two days worth of work to just review the entire patch,
> simply because the scope of the changes is so huge.
I agree, but we had to get it finished fast, because of =
christmas-shopping.
I'll diff and post the configuration-only refactored later this day.
Maybe this will be a good starting point for introducing minilzo.
Joey5337
Content-Type: application/ms-tnef;
name="winmail.dat"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...[email truncated]...
