Re: [Nagios-devel] Re: Possibly typos in checkcommands.cfg
I had forgot to modify the sample checkcommands.cfg file with $ARG1$
and $ARG2$ options in the check_ping command definition. That was
how it was intended to be configured. Anyway, fix is in CVS.
On 8 Jun 2002 at 15:11, Jun Kuriyama wrote:
> > For the first two - I think the numbers were put in such that a decent
> > default would exist for new users. It is meant to ease them into using
> > and understanding the config files.
> OK, that's reasonable. Then should it be modified as like this?
> Index: services.cfg.in
> RCS file: /cvsroot/nagios/nagios/sample-config/template-object/services.cfg.in,v
> retrieving revision 1.2
> diff -u -r1.2 services.cfg.in
> --- services.cfg.in 10 Mar 2002 23:49:27 -0000 1.2
> +++ services.cfg.in 8 Jun 2002 06:09:38 -0000
> @@ -107,7 +107,7 @@
> notification_interval 120
> notification_period 24x7
> notification_options c,r
> - check_command check_ping!100.0,20%!500.0,60%
> + check_command check_ping
> @@ -183,7 +183,7 @@
> @@ -202,7 +202,7 @@
> @@ -259,7 +259,7 @@
> @@ -316,7 +316,7 @@
> notification_interval 240
> @@ -430,7 +430,7 @@
> @@ -544,7 +544,7 @@
> @@ -563,7 +563,7 @@
> @@ -582,7 +582,7 @@
> @@ -601,7 +601,7 @@
> @@ -620,7 +620,7 @@
> @@ -639,7 +639,7 @@
> @@ -677,7 +677,7 @@
> notification_interval 960
> notification_period workhours
> @@ -714,7 +714,7 @@
> @@ -751,7 +751,7 @@
> Jun Kuriyama // IMG SRC, Inc.
> // FreeBSD Project
> ___________________________________
...[email truncated]...
