--------------090904060002070706050503
Sean Millichamp wrote the following on 04.11.2009 16:07:
> Actually, api_query hasn't been initialized up until that point. The
> api_query pointer in your first asprintf is dependent on the results of
> the asprintf in your else clause. If you wanted to rewrite it then it
> would need to be more like:
> if(bare_update_check==FALSE) {
> asprintf(&api_query,"v=1&product=icinga&tinycheck=1&stableonly=1&version=%s%s",PROGRAM_VERSION,(api_query_opts==NULL)?"":api_query_opts);
> } else {
> asprintf(&api_query,"v=1&product=icinga&tinycheck=1&stableonly=1");
> This does cause some duplication in the strings, but does otherwise look
> a bit cleaner.
Ah, yeah, I knew I missed sth on that. Thanks for clearifying! Regarding
the duplicated string, maybe an extra buf is needed.
> I think that is a fine solution and also much cleaner looking. I was
> trying to keep changes to the style to a minimum, but it is often hard
> to best know how to do that for a given project.
To be honest, I don't really like the style of code in there. And for
what it's worth some solutions are much more comfortable to implement
not regarding the easier reading. That's a thing coming from rewriting
IDOUtils for more RDBMs, I hesitated several times with good looking
lines but not that easy code.
> Which would hopefully allow the asprintf() style calls in the same
> fashion as they had been used, except substituting my_asprintf() for
> them.
asprintf is heavily used within the code so it would be a good option.
Compared to how much work it would be rewriting adn aptching that, well.
> And, yes, the current code does cause a small memory leak. As far as I
> can see, asprintf always malloc()s new memory and places the pointer in
> the first argument without using the existing value (no realloc, free,
> etc.) I found it while running valgrind on Nagios while pursuing a
> different problem and figured it was worthy of a janitorial patch.
Jep, asprintf allocated buffers need to be free'd manually. If you take
a deeper look into e.g. NDOUtils dbhandler.c you will find lots of those
statements. It's pure C but the bigger the code the more you have to
correct afterwards
Kind regards,
Michael
DI (FH) Michael Friedrich
[email protected]
Tel: +43 1 4277 14359
Vienna University Computer Center
Universitaetsstrasse 7
A-1010 Vienna, Austria
Content-Type: text/html; charset=ISO-8859-1
} else {
a bit cleaner.
Regarding the duplicated string, maybe an extra buf is needed.
...[email truncated]...
