[Nagios-devel] Static length for string variables in objects
I'm working on adding inherent redundancy to Nagios through a loadable
module (which will eventually turn to a fullblown cluster solution). The
fact that host_name and friends are pointers as opposed to char arrays
(char *host_name instead of char host_name[MAX_OBJECT_NAME_LEN]) makes
it immensely more difficult. Also, the lack of index lookup tables makes
it impossible to simply send an object type and id.
So... would a patch to fix this be welcome? It's a fairly major code
change but should simplify things immensely, not least in the memory
management parts of the code, although it will set hard limits on the
length of object names (I was thinking 40 chars) and aliases (I was
thinking 80 chars).
This would only have to be done for objects that are subject to checking
(hosts and services) but most likely other kinds of objects would
benefit from this type of database style normalization as well.
OP5 AB www.op5.se
Lead Developer
