--------------020701010308080403000402
Content-Type: text/plain; charset=ISO-8859-1
On 1/26/2010 5:22 PM, Ton Voon wrote:
> I haven't looked in detail, but a test case will help! If you can update
> the test configuration with your new feature and prove that the error is
> fixed, then it will make it much easier to evaluate.
> Details on configuration
> tests: http://wiki.nagios.org/index.php/Nagios ... file_tests
> If you do this, poke me and I'll get the commit done.
Thank you very much Ton! I appreciate you taking the time to reply. I
have done as you suggested and have attached an updated patch; this
patch includes the original change as well as an update to minimal.cfg
and objects.precache.expected; this configuration will fail with a
nagios binary compiled before the xodtemplate.c patch was applied, but
succeed with a binary compiled with the patch applied. Any further
suggestions/requests that would help with acceptance of the patch are
welcomed!
BTW, I've also added this patch to the tracker issue #102 I had opened:
http://tracker.nagios.org/view.php?id=102
Best Regards,
Tim Wilde
Content-Type: application/x-itunes-itlp;
name="xodtemplate-with-tests.patch"
filename="xodtemplate-with-tests.patch"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...[email truncated]...
