Re: [Nagios-devel] gSOAP communication between modules/plugins
I suggest looking at integration with openwsman for plugin:
http://sourceforge.net/projects/openwsman/
It should be pretty easy to link to the library or just write perl wrapper
and you need not worry about underlying details of the protocol and its
security features.
As far as making nagios data available through wsman that's bigger
project and should be not just wsman but snmp as well.
P.S. Personally i've not yet run across anywhere where wsman is used
and I'm in touch with number of companies.
On Fri, 27 Apr 2007, Paul Millar wrote:
> Hi Sebastian,
> On Friday 27 April 2007 14:23, Sebastian Ganame wrote:
>> However, WS-MAN (along with WS-Notification, WS-Eventing, etc.) are taking
>> the lead when it comes to Datacenter manageability. In the near future,
>> most of the devices currently implementing SNMP traps for alerting (just as
>> an example) will also support WS-MAN for device management, and maybe
>> having the alternative to get there is one area that Nagios might/should
>> investigate.
> Yes, WS-Man looks pretty interesting.
> Are you thinking this is something Nagios should be able to monitor (as in
> some kind of check_wsman plugin), or that Nagios' current status should
> somehow be made available via WS-Man?
> BTW, out of curiosity, do you know of any kit that supports WS-Man just now?
> There's a few software solutions out there, so I guess its possible for
> existing software to be instrumented with WS-Man. Looks like Win. Server
> 2003 supports it (and some Sun hardware) but I was wondering if anything else
> does.
>> I understand however that adding XML based protocols like Web
>> Services for data gathering might impact Nagios performance, since both XML
>> parsing (very time-consuming) as well as increased network traffic might
>> affect Nagios performance. I really would like to listen to ideas and or
>> opinions regarding this.
> Well, from what I've heard, the killer for short interaction WS-based services
> is actually the crypto stuff (e.g. validating the TLS chain of trust) rather
> than serialising/deserialising the XML. I guess if one can keep the
> connection live (via HTTP/1.1 persistent connections), this can be mitigated,
> but then you need something (Nagios-side) that stays alive between successive
> probes.
> If the probes are genuinely stateless, then RFC 4507 has some ideas about how
> best to go about caching the connection-credentials, but I guess it depends
> largely on what the server supports.
> Of course, this isn't a problem if there's no security. But since WS-Man
> gives you control of the device, is anyone implementing it without at least
> some level of TLS support (e.g. with just Diffie-Hellman)?
> Cheers,
> Paul.
