[Nagios-devel] Fix: Nagios + OpenBSD 3.4 not recognizing GD libraries
Hey folks,
I've been beating my head against this for a little while as I try to
find time to work on an OpenBSD port for Nagios... Nagios, when built on
an OpenBSD 3.4 (possibly 3.3 as well) machine, will not find GD even when
--with-gd-lib and --with-gd-inc are specified on the configure command
line.
This is due to the need to have the following specified when running
the configure script:
LDFLAGS="-L/usr/local/lib -lttf"
So, on an OpenBSD machine with png, jpeg, gd, and ttf installed from
the OpenBSD ports tree, the following works fine:
env LDFLAGS="-L/usr/local/lib -lttf" ./configure
Using this, you do not need to specify --with-gd-lib and --with-gd-inc.
HUGE kudoes go to Julien Touche, who figured out these details.
I'm assuming configure.in needs to be modified, but I suck too much as
a developer to figure it out. :) Hopefully, it'll help someone in the
future.
Benny
"Legend has it that once 100 posts have been made, The Dark Lord
Bernstein will rise from the prison of ice and wage his inevitable
war on mankind." -- Erik Bourget
