--00c09f9b0ba5c032cc048c296b07
Content-Type: text/plain; charset=ISO-8859-1
If I submit a DEL_HOST_COMMENT or DEL_SVC_COMMENT line to the named pipe of
Nagios i see a line like this in nagios.log:
[1280008668] EXTERNAL COMMAND: DEL_HOST_COMMENT;host-name;19117
No errors follow, but the comment is not deleted - still shows up in
status.dat and retention.dat, even if I wait till the retention.dat interval
is reached, even if I shut down Nagios normally the change is not persisteed
/ processed properly.
If I submit a DEL_ALL_HOST_COMMENTS or DEL_ALL_SVC_COMMENTS API command to
the named pipe, the operation works within seconds.
From the Nagios UI - same thing for both operations, which makes sense since
it just submits to the named pipe as well.
I am trying to track down what code is failing for the DEL_HOST|SVC_COMMENT
commands now - if any of you have seen this behavior before or know what
might be causing it, would welcome the feedback.
Again, this happens when submitting commands directly to the Nagios named
pipe.
- Max
Content-Type: text/html; charset=ISO-8859-1
Hi,If I submit a DEL_HOST_COMMENT or DEL_SVC_COMMENT line to the na=
med pipe of Nagios i see a line like this in nagios.log:[1280008668=
] EXTERNAL COMMAND: DEL_HOST_COMMENT;host-name;19117No errors follo=
w, but the comment is not deleted - still shows up in status.dat and retent=
ion.dat, even if I wait till the retention.dat interval is reached, even if=
I shut down Nagios normally the change is not persisteed / processed prope=
rly.
If I submit a DEL_ALL_HOST_COMMENTS or DEL_ALL_SVC_COMMENTS API command=
to the named pipe, the operation works within seconds.From the Nag=
ios UI - same thing for both operations, which makes sense since it just su=
I am trying to track down what code is failing for the DEL_HOST|SVC_COM=
MENT commands now - if any of you have seen this behavior before or know wh=
at might be causing it, would welcome the feedback.Again, this happ=
ens when submitting commands directly to the Nagios named pipe.
- Max
--00c09f9b0ba5c032cc048c296b07--
