Re: [Nagios-devel] don't log passive host_checks patch
Thanks!
Sven Strickroth wrote:
> Hi,
> in the config-file there is written:
> "# If you don't want Nagios to log passive host and service checks..."
> But the regarding check in commands.c doesn't check for
> passive_host_checks. My attached patch should fix that (the patch is
> against 2.9, but should apply to cvs, too).
> diff -Nur nagios-2.9-orig/base/commands.c nagios-2.9/base/commands.c
> --- nagios-2.9-orig/base/commands.c 2007-08-14 02:58:13.000000000 +0200
> +++ nagios-2.9/base/commands.c 2007-08-14 02:58:26.000000000 +0200
> @@ -563,7 +563,7 @@
> /* log the external command */
> snprintf(buffer,sizeof(buffer),"EXTERNAL COMMAND: %s;%s\n",command_id,args);
> buffer[sizeof(buffer)-1]='\x0';
> - if(command_type==CMD_PROCESS_SERVICE_CHECK_RESULT){
> + if(command_type==CMD_PROCESS_SERVICE_CHECK_RESULT || command_type==CMD_PROCESS_HOST_CHECK_RESULT){
> if(log_passive_checks==TRUE)
> write_to_all_logs(buffer,NSLOG_PASSIVE_CHECK);
Ethan Galstad,
Nagios Developer
Email: [email protected]
