[Nagios-devel] NDOUtils 1.4b1 Released
Its been quite a while since I released an update to the NDOUtils addon,
but the time has finally arrived. I just squashed some big bugs and
released 1.4b1, so give it a try and let me know (on the -devel list)
what does/doesn't work. Its a beta release, so don't if you're using a
prior version for production purposes, use caution with this.
The new release has a slightly different DB structure (there's a script
that should upgrade the 1.3 table structures) and the default table
prefix is now "nagios_" instead of "ndo_". Should work with Nagios 2.x
and the Nagios 3 alpha CVS code.
The new release also has a separate PDF document describing the DB
structure. Its 55 or so pages and doesn't cover the ~20 tables
containing configuration data yet, but that will get filled in for
future releases. Thanks to Marlo Bell for his early Visio diagram
several months back - it was a great start for the docs!
Ethan Galstad,
Nagios Developer
Email: [email protected]
