Re: [Nagios-devel] Patch for NDOUtils 1.4b2 with RHEL4 64-bit and
On 10 Apr 2007, at 17:16, Ethan Galstad wrote:
> Alex Burger wrote:
>> When using ./configure on RHEL4 64bit, I was getting:
>> *** MySQL library could not be located... **************************
>> Using ./configure --with-mysql-lib=/usr/lib/mysql didn't work because
>> there is a bug in configure. Attached is a patch.
> Thanks - patch will be in CVS shortly...
Hi!
Can I remind that I think this is a better patch: http://
altinity.blogs.com/dotorg/2007/04/better_mysqlcli.html
It uses the same mysql detection as the plugins, and should cater for
32/64bit, library detection, header files, a test compile, etc, etc.
Ton
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
