Re: [Nagios-devel] PHP user interface for Nagios
This is good. I'm using Nagios in a context where I need form-based
authentication. It would also be helpful if you could have screens to
"edit config" as well as view it.
--- Jesús M. NAVARRO wrote:
> Hi, list:
> I've been hacking some PHP files for a Nagios UI. I read what's
> about PHP
> from the Nagios developer team perspective (that is; it would be
> nice, but
> it's not high in their todo list) so I designed this as a fast
> drop-in
> replacement for what's already there.
> Major characteristics:
> * GPL (of course, while I still haven't included GPL notices within
> source
> files).
> * "Proper" authentication through sessions (it uses Apache files from
> htpasswd
> and reads roles from the cgi.cfg nagios' file).
> * Themes support (through the use of Smarty templates).
> * No need of cgi support (it includes php wrappers which call in turn
> the cgi
> executables through system calls) nor cgi rewriting (the php files
> use cgi
> extension so hardcoded links within the cgis point to the correct
> locations).
> What is still not there?
> * The wrappers for CGIs that embed figures (like statusmap.cgi and
> some
> reports) don't work yet.
> * The wrappers for CGIs that use both GET and POST variables (notably
> cmd.cgi)
> don't work either.
> What do I want to achieve?
> * End up with fully separated functionallity from nagios "core" (the
> engine
> and plugins) and nagios-ui (the user interface).
> * Fully themeable and multi-language support.
> * Easy to deploy environment (so it's easy for everyone to modify ui
> to their
> own needs through themes and/or new php code).
> You can find it at http://www.undominio.net/nagios_ui/index.html
> I'd want to know about your feedback and opinions.
> TIA.
> SALUD,
> Jesús
> [email protected]
> This SF.net email is sponsored by: eBay
> Get office equipment for less on eBay!
> http://adfarm.mediaplex.com/ad/ck/711-11697-6916-5
> Nagios-devel mailing list
> [email protected]
