Re: [Nagios-devel] module/helloworld.c failing to build
David Halik wrote:
> I've had some difficulty getting module/helloworld.c to build and link
> in Solaris 9 with SunStudio. RC1 was the first time I've seen this
> particular problem since the betas all built fine. See below:
> gmake[1]: Entering directory
> `/usr/local/src/rpm-packages/BUILD/nagios-3.0rc1/module'
> cc -I/usr/local/include -DHAVE_CONFIG_H -o helloworld.o helloworld.c -G
> -L/usr/local/lib -R/usr/local/lib -L/usr/sfw/lib -R/usr/sfw/lib
> -L/usr/local/lib -lrt
> "/usr/include/dlfcn.h", line 149: warning: macro redefined: RTLD_NOW
> "/usr/include/dlfcn.h", line 152: warning: macro redefined: RTLD_GLOBAL
> "helloworld.c", line 39: warning: syntax error: empty declaration
> "helloworld.c", line 76: warning: argument #8 is incompatible with
> prototype:
> prototype: pointer to void : "../include/nagios.h", line 491
> argument : pointer to function(pointer to char) returning void
> ld: fatal: file helloworld.o: unknown file type
> ld: fatal: File processing errors. No output written to helloworld.o
> gmake[1]: *** [helloworld.o] Error 1
Thanks for the note. I'll get a patch into CVS shortly that should fix
this problem.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
