Milos Wimmer wrote:
> On Tue, 8 Nov 2005, Milos Wimmer wrote:
> Hello,
> I did not receive any answer to my previous bug report about missing
> "View Trends For This Host" and "View Trends For This Service" links in
> the nagios/cgi-bin/extinfo.cgi pages (in nagios-cvs tarball), so I
> looked more detailed at this thing and I found where the problem is -
> configure script generates bad definitions in include/cgiutils.h file.
> It creates following lines:
> /* #undef USE_STATUSMAP */
> /* #undef USE_STATUSWRL */
> /* #undef USE_TRENDS */
> /* #undef USE_HISTOGRAM */
> instead of:
> #define USE_STATUSMAP 1
> #define USE_STATUSWRL 1
> #define USE_TRENDS 1
> #define USE_HISTOGRAM 1
This is because the configure script doesn't pick up your GD
installation (although it should build statuswrl regardless).
> As a result of that extinfo.cgi does not support trends and does not
> include them in its "Views menu".
> When I changed that definitions by the hand, all works fine.
> Please, could you look at it?
Where is your gd-library installed? Did you pass it as an option to
./configure ?
OP5 AB www.op5.se
