On Wed, 13 Aug 2008 11:27:12 +0200, Armin Wolfermann
wrote:
>* Jon Angliss [12.08.2008 23:52]:
>> I read the thread, and it looks like the variables are being double
>> encoded, which is fine, but the issue here is that a variable being
>> fed into url_encode is coming out as a different variable.
>Ok, now I see the problem. url_encode() uses a static buffer and calling
>it twice in a row overwrites the first result. Half of a fix for this
>problem was committed in May introducing a second buffer but the code is
>only using the first.
I figured it had something to do with that, but my C skills are rather
rusty.
>I attached a patch against current CVS using dynamic buffers like
>html_encode() does. Lightly tested but works for me.
Seems to work quite nicely against CVS HEAD from last night.
Jon Angliss
