Network status map and graphs
I am now using the centos image. Everything is going ok, but I cant get the network status map or graphs to work. I ran the reset permissions script and I have reset the credentials.
Re: Network status map and graphs
Also when I apply a configuration it says "waiting for configuration verification...................." and it never refreshes.
Try these two steps and let us know the results that you get:
Try using the Write Config Tool in the Core Config Manager to manually write out the config files and restart Nagios.
Try running:
This is the same as selecting "Apply Configuration" from the web interface. Make note of any error output you get from this. You may have to hit enter at the end of the script to close it out.
Try running:
/usr/local/nagiosxi/scripts/reconfigure_nagios.shRe: Network status map and graphs
I ran through the steps. when I ran
I had these error messages
/usr/local/nagiosxi/scripts/reconfigure_nagios.shCode: Select all
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh: line 6: ./import_nagiosql.sh: No such file or directory
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh: line 9: ./restart_nagios_with_export.sh: No such file or directory
Can you show us the contents of the /usr/local/nagiosxi/scripts directory?
You said this was on our CentOS VM?
ls -lRe: Network status map and graphs
# ls -l /usr/local/nagiosxi/scripts/
total 324
-rw-r--r-- 1 nagios nagios 45 Jan 11 2010 1263222026.tar.gz
-rw-r--r-- 1 nagios nagios 0 Jan 11 2010 1263222026.txt
-rwxr-xr-x 1 nagios nagios 2757 Nov 15 13:50 backup_xi.sh
-rwxr-xr-x 1 nagios nagios 352 Nov 15 13:50 export_nagiosql.sh
-rwxr-xr-x 1 nagios nagios 1017 Nov 15 13:50 fixperms.sh
-rwxr-xr-x 1 nagios nagios 821 Nov 15 13:50 handle_nagioscore_event.php
-rwxr-xr-x 1 nagios nagios 829 Nov 15 13:50 handle_nagioscore_notification.php
-rwxr-xr-x 1 nagios nagios 259 Nov 15 13:50 import_nagiosql.sh
-rwxr-xr-x 1 nagios nagios 149 Nov 15 13:50 kill_rrdtool.sh
-rwxr-xr-x 1 nagios nagios 90 Jan 10 09:23 nagiosql.cookies
-rwxr-xr-x 1 nagios nagios 15810 Jan 7 12:12 nagiosql.delete.contact
-rwxr-xr-x 1 nagios nagios 757 Nov 15 13:50 nagiosql_delete_contact.php
-rwxr-xr-x 1 nagios nagios 748 Nov 15 13:50 nagiosql_delete_host.php
-rwxr-xr-x 1 nagios nagios 505 Nov 15 13:50 nagiosql_delete_object.sh
-rwxr-xr-x 1 nagios nagios 757 Nov 15 13:50 nagiosql_delete_service.php
-rwxr-xr-x 1 nagios nagios 21347 Jan 7 12:12 nagiosql.delete.timeperiod
-rwxr-xr-x 1 nagios nagios 780 Nov 15 13:50 nagiosql_delete_timeperiod.php
-rwxr-xr-x 1 nagios nagios 0 Jan 10 09:23 nagiosql.export.additional
-rwxr-xr-x 1 nagios nagios 864 Nov 15 13:50 nagiosql_exportall.php
-rwxr-xr-x 1 nagios nagios 0 Jan 10 09:23 nagiosql.export.monitoring
-rwxr-xr-x 1 nagios nagios 1004 Nov 15 13:50 nagiosql_importall.php
-rwxr-xr-x 1 nagios nagios 34542 Jan 7 12:13 nagiosql.import.monitoring
-rwxr-xr-x 1 nagios nagios 0 Jan 10 09:23 nagiosql.login
-rwxr-xr-x 1 nagios nagios 1154 Nov 15 13:50 nagiosql_login.php
-rwxr-xr-x 1 nagios nagios 258 Nov 15 13:50 nagiosql_trim_backups.sh
-rwxr-xr-x 1 nagios nagios 515 Nov 15 13:50 nom_create_nagioscore_checkpoint_cond.sh
-rwxr-xr-x 1 nagios nagios 716 Nov 15 13:50 nom_create_nagioscore_checkpoint.sh
-rwxr-xr-x 1 nagios nagios 631 Nov 15 13:50 nom_create_nagioscore_errorpoint.sh
-rwxr-xr-x 1 nagios nagios 784 Nov 15 13:50 nom_restore_nagioscore_checkpoint.sh
-rwxr-xr-x 1 nagios nagios 2104 Nov 15 13:50 nom_trim_nagioscore_checkpoints.sh
-rwxr-xr-x 1 nagios nagios 2961 Nov 15 13:50 patch_ndoutils.php
-rwxr-xr-x 1 nagios nagios 246 Nov 15 13:50 reconfigure_nagios.sh
-rwsr-xr-x 1 root nagios 5258 Nov 15 13:50 reset_config_perms
-rw-r--r-- 1 nagios nagios 280 Nov 15 13:50 reset_config_perms.c
-rwsr-xr-x 1 root nagios 484 Nov 15 13:50 reset_config_perms.sh
-rwxr-xr-x 1 nagios nagios 1155 Nov 15 13:50 reset_nagiosadmin_password.php
-rwxr-xr-x 1 nagios nagios 850 Nov 15 13:50 restart_nagios_with_export.sh
-rwxr-xr-x 1 nagios nagios 4010 Nov 15 13:50 restore_xi.sh
This was on your cent vm
I would try restarting the server. I've heard of similar issues before on manual installs, but not usually on our VM.
If that doesn't work:
Are you able to get the configuration to go through by walking through the steps in the "Write Config Tool" in the Core Config Manager?
I restarted the server with no luck. I made it so that everything is using ssl and turned off port 80. Is there a way that I can have everything using ssl and shut off port 80 and have it all work? Also on my performance graphs I changed the time on the system to be correct, but the time in nagiosxi is an hour off still. That obviously causes problems with the times that the server is up or down and I would assume causing problems with my graphs. How do I change the time in nagiosxi?
The performance graphs are grabbed in XI using a proxy, so I'm guessing that would potentially be the problem by turning off port 80.
If your system time is off in the browser, but ok on the server, then it might be a setting in your php.ini file. You might have to set your timesone, particularly if you're running php 5.3+.
