Re: [Nagios-devel] Semicolons in plugin output
Jason Hoos wrote:
> Quick question - what is the reason behind the conversion of semicolons
> in plug-in output to colons? Is it to prevent issues with parsing of
> status.dat?
I believe this is because the plugin-output is usually sent to other commands
via the shell (fe, notifications). Semi-colon is a special shell character
and as such should never be sent there raw.
If the above explanation is the case, it would be better (and slightly
better, performance-wise) to do the semicolon-to-colon conversion when
the string is passed to the shell.
> The reason I ask is that I have some plug-ins that output HTML entities
> (which all end in semicolons of course),
Why do they end in semicolons? I'd have thought a greater-than sign would
end HTML entities. Mind you, those are also special shell characters.
OP5 AB www.op5.se
