Tobias Scherbaum wrote:
> > can you verify if the path "/var/spool/nagios3/checkresults" is existing
> > on your system?
> Sure it exists ... plus Nagios is able to create a handful of temporary
> queue files, which makes this even more weird. Not even the debug.log
> has any useful information which file Nagios fails to
> access exactly ...
> (snip)
> [1199372484.065535] [016.2] [pid=3545] Moving temp check result file
> '/var/spool/nagios3/checkresults/checkNmJmfN' to queue file
> ts/ccfuOCQ'...
> (snip)
> [1199372487.135649] [001.0] [pid=3529] reap_check_results() start
> [1199372487.135691] [016.0] [pid=3529] Starting to reap check results.
> ... and then it segfaults
Funny, found exactly the same problem in a thread in the German Nagios
forum [1] ... not that it has a solution/fix though.
Tobias
[1]
http://www.nagios-portal.de/wbb/index.p ... 2&pageNo=1
