I don't know if this is the right list for NDO, but i'll learn it on the hard way, though.
I installed NDO into a CentOS, and when i started Nagios i received the following message at nagios.log:
ndomod: Could not open data sink! I'll keep trying, but some output may get lost...
I figured out that nagios' user couldn't access NDO configuration file due to a permission issue. It took me some time to discover the source of the problem, so i thought that maybe an accurate error message can help on this.
I've applied the patch below against ndoutils-1.4b9.
--- ndomod.c 2009-10-27 01:08:29.000000000 -0700
+++ ndomod.c-modified 2011-01-05 03:40:08.000000000 -0800
@@ -330,10 +330,15 @@
ndo_mmapfile *thefile=NULL;
char *buf=NULL;
int result=NDO_OK;
+ char temp_buffer[NDOMOD_MAX_BUFLEN];
/* open the file */
- if((thefile=ndo_mmap_fopen(filename))==NULL)
+ if((thefile=ndo_mmap_fopen(filename))==NULL) {
+ snprintf(temp_buffer,sizeof(temp_buffer)-1,"ndomod: Unable to open configuration file, please check permissions.\n");
+ temp_buffer[sizeof(temp_buffer)-1]='\x0';
+ ndomod_write_to_logs(temp_buffer,NSLOG_INFO_MESSAGE);
return NDO_ERROR;
/* process each line of the file */
while((buf=ndo_mmap_fgets(thefile))){
