I have a problem generating graphs with nagiosgrapher.
I have defined several services that have been monitorized every 5 minutes (24x7).
Everything seems to be ok, these services are being monitorized properly at this time and checking logs in nagiosgrapher aparently everything is right.
But when you see the graph the information is not been represented at the right time.
Here i show anexample of a service:
cpu_stats log status: 2011-01-17 13:12:57 VALUES:CPU_Stats]:CPU_NICE=0.00 CPU_STEAL=0.00 CPU_USER=3.00 CPU_IOWAIT=0.00 CPU_IDLE=88.50CPU_SYSTEM=8.50
It seems that the last check it was at 13:12:57 but checking the graph seems like this service is being checked just from 23 until 7.
This is just one case, but i got the same error for several services. I attach an image.
Thanks for any help,
nagiosgrapher error
mlorentegarcia
nagiosgrapher error
- grafica2.png (88.05 KiB) Viewed 905 times
