[Nagios-devel] nagios 3.0 remarks
Hi list,
First : After compilation, Nagios gives you a nice screen giving you =20
options to pass to the make install command. It seems that it has not =20
been updated for three because it lacks the make install-webconf.
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install-init
- This installs the init script in /etc/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs sample config files in /usr/local/nagios/etc
Second : active_host_enabled in nagios.cfg and in host definitions. =20
tac.cgi confirms that fact but in the web interface menu view =20
configuration --> view config --> hosts says it is not.
That's all for the moment ;-) Nagios 3 rocks !!!
Olivier Jan
