Re: [Nagios-devel] Feature Request for check_disk
On Fri, 2003-03-21 at 05:38, [email protected] wrote:
> Hi everybody out there,
> I have an idea to make a good product (check_disk in my case) even better.
> I use the plugin to check all filesystems at once (e. g. check_disk -w 20%
> -c 10% -m)
> Now if an administrator puts a cdrom into one server and mounts it, the
> plugin returns a critical state. But of course I don't like getting alarms
> because of that.
> Ok, I could check all other filesystems separately, but this is also not,
> what I want, because it needs additional administration at nagios everytime
> an administrator does changes on filesystems.
> The best way would be to have a parameter that tells check_disk to check
> every filesystem excepting the given one (or more) e. g. excepting
> /dev/cdrom and /dev/cdrom1
The version is check_disk in development will (soon) exclude iso9660
filesystems by default. You will be able to add them manually if you
want.
Karl
