Re: [Nagios-devel] [Fwd: Memory leak in Nagios head]
Looks like the real culprit is the setenv() system command.
Apparently, memory "freed" by the unsetenv() command is not actually
freed, causing the leak. I added this feature within the last few
weeks to allow macro variables to be avaiable as env vars in all
commands. Too bad this causes problems, as it would have been a nice
feature.
For the time being, I have simply made the
set_macro_environment_var() function in utils.c return without doing
anything. This seems to fix the problem, although I am sure there
are a few small leaks elsewhere.
On 29 Nov 2004 at 21:34, Andreas Ericsson wrote:
> Matthew Kent wrote:
> > Forwarding this on in case anyone else has seen this behaviour and
> > has some suggestions. I'll give it a run through valgrind and see if
> > I can spot anything this evening.
> Thanks, Matt.
> A small update;
> After having run the daemon about 10 hours at a test system, memory
> consumption has escalated from roughly 1MB to around 24MB. Not very
> nice figures. It seems that sending a HUP makes memory consumption
> make a small jump (usually around 20K).
> This small script should crash Nagios after a while. It might have to
> be run more than once. I haven't tried it very much. It works
> regardless of whether or not the eventbroker is compiled in.
> #!/bin/sh
> pid=`cat /usr/local/nagios/var/nagios.lock`
> for i in `seq 1 100`; do
> kill -HUP $pid
> sleep 1
> ps -up $pid || break
> done
> [ $i -ne 100 ] && echo "Nagios successfully crashed"
> With --enable-DEBUGALL, this output is shown by tailing the last 20 or
> so lines of the output.
> find_host() start (repeats about 40 or so times)
> write_to_all_logs() start
> write_to_syslog() start
> write_to_log() start
> write_to_all_logs() end
> Caught SIGSEGV, shutting down...
> close_command_file() start
> close_command_file() end
> write_svc_message() start (repeats 4 times)
> Another weird thing is that the SIGSEGV crash causes Nagios to remove
> the lockfile, but not the objects.cache-file, which causes the
> webinterface to happily chug on as if nothing's happened. That should
> be fairly easily fixed, but I'd rather get to the bottom of the memory
> leak.
> > Subject:
> > From:
> > Andreas Ericsson
> > Date:
> > Mon, 29 Nov 2004 12:47:27 +0100
> > To:
> > [email protected]
> > To:
> > [email protected]
> > CC:
> > [email protected]
> > Ahoy Ethan.
> > There's a memory leak in Nagios HEAD, causing it to crash when (it
> > seems) enough checks has been executed. I would have emailed the
> > nagios-devel list but I believe I'm still banned from it pending a
> > solution to the sourceforge list server fuckup? Could one of you
> > forward this to that list, please?
> > It's compiled without embedded perl, and without perl caching, like
> > so; ./configure --prefix=/opt/monitor
> > I'll start digging today, so I might have a patch ready for you
> > soon.
> > I Cc'ed Matthew Kent on this as well, seeing as he's been very
> > helpful with the finding and fixing earlier.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Lead Developer
> SF email is sponsored by - The IT Product Guide
> Read honest & candid reviews on hundreds of IT Products from real
> users. Discover which products truly live up to the hype. Start
> reading now. http://productguide.itmanagersjournal.com/
> _______________________________________________ Nagios-devel mailing
> list [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
