Good catch! I'll get CVS updated shortly. Thanks.
Sébastien Barbereau wrote:
> Hi,
> as I've been playing with the new 1.4b1 of the ndo databroker I noticed
> that the nagios_service_contacts and nagios_host_contacts are not
> properly "updated".
> When ndo2db is updating the nagios_host_contacts table he does :
> INSERT INTO nagios_host_contacts SET instance_id='1', host_id='3',
> contact_object_id='34' ON DUPLICATE KEY UPDATE instance_id='1',
> host_id='3', contact_object_id='34';
> and then
> contact_object_id='41' ON DUPLICATE KEY UPDATE instance_id='1',
> host_id='3', contact_object_id='41';
> But the table structure states that only instance_id is a unique key
> therefore nagios_host_contacts contains only the latest entry and not
> any other host to contact information ...
> So you need to change the nagios_host_contacts and
> nagios_service_contacts tables by adding them as unique keys.
> Sorry if this was already report ...
> Seb.
Ethan Galstad,
Nagios Developer
Email: [email protected]
