Looks like this was due to a bug in the external command circular
buffer processing logic. I posted a fix to CVS last night, so check
out the latest version from CVS and see if that fixes things.
On 4 Nov 2004 at 19:55, Wickus Botha wrote:
> Please visit http://www.tiscali.co.za/business/did_you_know.htm
> ----------------------------------------- This is the output i receive
> from gdb when i do the process passive host checks
> (gdb) bt
> #0 0x00177a60 in strncpy () from /lib/tls/libc.so.6
> #1 0x08053249 in check_for_external_commands () at commands.c:136 2
> #0x0805a775 in handle_host_event (hst=0x816ceb8) at sehandlers.c:428 3
> # 0x0805aaf0 in handle_host_state (hst=0x816ceb8) at sehandlers.c:666
> #4 0x08054527 in process_passive_host_check (check_time=1099590946,
> #host_name=0x816d0b8 "DOWN", return_code=0,
> output=0xfee0e7a0 "UP") at commands.c:2040
> #5 0x08054207 in cmd_process_host_check_result (cmd=87,
> #check_time=1099590946, args=0xfee0e980 "mail1;0;UP|")
> at commands.c:1879
> #6 0x08051ef5 in check_for_external_commands () at commands.c:560 7
> #0x080574aa in event_execution_loop () at events.c:1040 8 0x0804a259
> #in main (argc=135680008, argv=0xfee0f5f0) at nagios.c:663
> -----Original Message-----
> From: Wickus Botha
> Sent: Tuesday, November 02, 2004 11:20 AM
> To: '[email protected]'
> Subject: Process Host Check Results
> Hi
> I'm currently testing the process host check results but every now and
> then actually every time i tested it nagios crashes. if u use the
> website to submit results it seems to working. But i did manage to
> break it. The other test is by using a script to write to the
> nagios.cmd file and let nagios process the results. If somebody has a
> test lab can they maybe try and simulate this. If there is more info
> regarding the test u need please drop me a mail.
> [1099385443] EXTERNAL COMMAND: PROCESS_HOST_CHECK_RESULT;mail1;1;DOWN|
> [1099385443] HOST ALERT: mail1;DOWN;HARD;1;DOWN [1099385443] HOST
> NOTIFICATION: usermail;mail1;DOWN;host-notify-by-email;DOWN
> [1099385444] EXTERNAL COMMAND: PROCESS_HOST_CHECK_RESULT;mail2;1;DOWN|
> [1099385444] HOST ALERT: mail2;DOWN;HARD;1;DOWN [1099385444] HOST
> NOTIFICATION: usermail;mail2;DOWN;host-notify-by-email;DOWN
> [1099385444] Caught SIGSEGV, shutting down...
> Thanks
> Wickus Botha
> This SF.Net email is sponsored by:
> Sybase ASE Linux Express Edition - download now for FREE
> LinuxWorld Reader's Choice Award Winner for best database on Linux.
> http://ads.osdn.com/?ad_id=5588&alloc_id=12065&op=click
> _______________________________________________ Nagios-devel mailing
> list [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
