I first tried running gdb on the "make install" version of the nagios
binary, gdb said there was no debugging symbols found, so I figure that
wouldn't be as useful. Copied the pre-make install binary (md5 sums
different) and ran gdb on that. Here is the output:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 1074195040 (LWP 32180)]
0x4207bfec in memcpy () from /lib/tls/libc.so.6
(gdb) where
#0 0x4207bfec in memcpy () from /lib/tls/libc.so.6
#1 0x0806e5a5 in mmap_fgets (temp_mmapfile=0x4036cffd) at utils.c:4696
#2 0x080704fe in xrddefault_read_state_information (
main_config_file=0x80b56e0 "/etc/nagios/nagios.cfg") at
../xdata/xrddefault.c:393
#3 0x0806f7fb in read_initial_state_information (
main_config_file=0x80b56e0 "/etc/nagios/nagios.cfg") at sretention.c:99
#4 0x080533a5 in main (argc=134960864, argv=0x80b56e0) at nagios.c:612
#5 0x42015504 in __libc_start_main () from /lib/tls/libc.so.6
After seeing this I see lines about reading initial_state_information.
I tried moving the saved state files somewhere else and nagios appears
to be working now. Thanks for your help guys
jl
Jason Martin wrote:
> On Thu, Nov 04, 2004 at 08:46:13AM +0000, Matthew Kent wrote:
>>Which should run nagios in the foreground as you've been doing. When it
>>dies, just type 'where' or 'bt'. It should show exactly where it crapped
>>out. Send that here. Now type 'kill' to end your session.
> I've found that since the 'make install' also strip's the
> binary, it is helpful to manually copy the nagios binary out of
> the build tree so that extra debugging information is available
> to gdb.
> -Jason Martin
