Re: [Nagios-devel] cfg_dir recursion not working
Hi
It seems the that the intention of cfg_dir is to include directories
recursively, but that it is broken. The code is there in
xodtemplate.c, but apparently buggy. If you change the line as
indicated by the diff below it should work... (there are still some
problems if you use symbolic links within your directory structure
though).
$diff xodtemplate.c ../../../tmp/nagios/xdata/xodtemplate.c
422c422
x=3Dstat(dirfile->d_name,&stat_buf);
Best regards,
Christian Theil Have.
On 7/14/05, Dr. Dave Blunt wrote:
> Unfortunately that's not what the 2.0 documentation says... From
> http://nagios.sourceforge.net/docs/2_0/ ... ml#cfg_dir I quote:
> "This directive is used to specify a directory which contains object
> configuration files that Nagios should use for monitoring. All files in t=
he
> directory with a .cfg extension are processed as object config files.
> Additionally, Nagios will recursively process all config files in
> subdirectories of the directory you specify here. You can seperate your
> configuration files into different directories and specify multiple cfg_d=
ir=3D
> statements to have all config files in each directory processed."
> Note the reference 'recursively process all config files in SUBDIRECTORIE=
S
> of the directory you specify here'.
> If that's a mistake then maybe the docs need to be updated but from a loo=
k
> at the code, it seems like it *should* recurse directories until it exhau=
sts
> it's search for config files or runs out of resources to do so.
> -----Original Message-----
> From: Subhendu Ghosh [mailto:[email protected]]
> Sent: Thursday, July 14, 2005 9:49 AM
> To: Dr. Dave Blunt
> Cc: [email protected]
> Subject: RE: [Nagios-devel] cfg_dir recursion not working
> cfg_dir will not recurse into sub-dirs.
> cfg_dir is used to read all "files" in the specified dir.
> On Thu, 14 Jul 2005, Dr. Dave Blunt wrote:
> > Indeed the files I want to include are all
> > /usr/local/nagios/etc/rps/*/*.cfg. There are other files in those subd=
irs
> > such as tar.gz files.
> > It's SuSE ES 9 and /usr/include/dirent.h is present. :(
> > Andreas Ericsson wrote:
> >> I have an install with a number of Nagios configs files stored under
> >> subdirectories:
> >> /usr/local/nagios/etc/rps//acfgfile
> >> /usr/local/nagios/etc/rps//anothercfgfile
> >> /usr/local/nagios/etc/rps//yetanothercfgfile
> > I suppose the files all match the glob(3) pattern
> > Otherwise, that's possibly the issue right there.
> >> There are no valid cfg files in /usr/local/nagios/etc/rps. All servic=
es
> > and
> >> hosts are defined in the cfg files under , , etc.
> >> When I define:
> >> cfg_dir=3D/usr/local/nagios/etc/rps
> >> in nagios.cfg the preflight check comes back with errors saying it can=
't
> >> find any hosts or services.
> > Are you running this on a Solaris or AIX platform? I think recursion
> > only works on system that has the header file, and that one
> > isn't present on all unices.
> -sg
> SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
> from IBM. Find simple to follow Roadmaps, straightforward articles,
> informative Webcasts and more! Get everything you need to get up to
> speed, fast. http://ads.osdn.com/?ad_id=3D7477&alloc ... op=3Dclic=
k
> Nagios-devel mailing list
> [email protected]
