Re: [Nagios-devel] Nagios indentation
On 11/19/2010 10:49 AM, Allan Clark wrote:
> On Fri, Nov 19, 2010 at 04:38, Andreas Ericsson wrote:
>> Unless someone complains before monday I'll add a Makefile target
>> to indent the sources, run it once and then commit the results, with
>> a note added so that future contributors know what to do to make
>> their code conform to the standard.
>> vim and emacs users should look into using their editors respective
>> 'smart tabs' settings. Most decent editors support aligning with
>> spaces and indenting with tabs nowadays, but if you're not using one
>> of them, you can just run 'make pretty' or 'make indent' before you
>> submit your patches.
> Why not make it an indentation filter in the .wrapper?
Because it's not scm-agnostic and we really, really hate cvs.
> That way, whatever formatting-butchery people accidentally do in their
> editors, the checkin is re-normalized automatically at the point of
> checkin.
A janitor commit every other month setting the style right (when patch
review lets one or more poorly formatted ones through) should be enough
to keep things mostly correct though.
OP5 AB www.op5.se
on peace.
