[Nagios-devel] SEGV in 2.0b2 (FreeBSD 4.10/200 hosts/330 active/300 passive) - repeatedly after 2-7 days running.
This is a multi-part message in MIME format...
------------=_1112435627-33147-183
Content-Disposition: inline
Dear Folks,
I am writing to report what may be a problem with Nag 2.0b2 (embedded
Perl, pthread lib, FreeBSD 4.10).
Nagios runs no more than 10 days before dieing with a SEGV.
Like a former report of SEGVs ('coredumps in wobbly
networks'/Ericsson/24 Mar 2005) there _may_ be a pattern in the logged
messages before the SEGV.
Exitting from scheduled downtime appears to be a health hazard.
In the last case,
Sat Apr 02 17:05:42 SERVICE DOWNTIME ALERT:
foo:bar via the blurfl provider
infrastructure;STOPPED; Service has exited from a period of scheduled
downtime
Sat Apr 02 17:06:18 Auto-save of retention data completed successfully.
Sat Apr 02 18:07:33 Nagios 2.0b2 starting... (PID=97771)
tsitc> grep nagios /var/log/messages
Apr 2 17:07:52 tsitc /kernel: pid 3400 (nagios), uid 1000: exited on
signal 11
And the one before,
Tue Mar 29 06:20:58 SERVICE ALERT: nada;TEC CPU;WARNING;HARD;1;The
percentage of CPU in idle state is low. This indicates high CPU
overload. date: 03/29/2005 06:20:50 AM eventid: 1112041070
557 modelname: DMXCpu name: total percidlecpu: 0 profilename:
ITM.OS.Unix_Dev_Monitoring.itm#IPAustralia-region source: TMNT status:
OPEN
Tue Mar 29 06:30:44 SERVICE DOWNTIME ALERT: yada;Standard host-centric
checks;STOPPED; Service has exited from a period of scheduled downtime
Tue Mar 29 06:30:44 SERVICE DOWNTIME ALERT: wurfl;COMS ad-hoc
check;STOPPED; Service has exited from a period of scheduled downtime
Tue Mar 29 06:30:44 HOST DOWNTIME ALERT: yada;STOPPED; Host has exited
Tue Mar 29 09:11:27 Nagios 2.0b2 starting... (PID=5473)
Mar 29 06:30:44 tsitc /kernel: pid 31467 (nagios), uid 1000: exited on
signal 11
Obviously it is easy to check whether scheduling downtime is causal; I
will give it a go and watch.
No core file.
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1112435627-33147-183--
