Re: [Nagios-devel] Strange service scheduling
----- "Hendrik Baecker" escreveu:
> Are you shure that the problem hits us, when the calculation is
> 'inside'
> a timeperiod?
If I send a valid timestamp to get_next_valid_time it will return the same valid time.
Take a look to base/checks.c at line 280:
get_next_valid_time(preferred_time,&next_valid_time,svc->check_period_ptr);
Suppose preferred_time is a valid timestamp within svc->check_period_ptr.
What is supposed to return from this call?
I supposed the return is: next_valid_time = preferred_time.
Look, some lines below we found:
if (time_is_valid==FALSE && next_valid_time==preferred_time) {
//schedule this check for next year
time_is_valid = FALSE can be achieved with a timeperiod change.
Lets try with an example:
service X, timeperiod 24x7, check_interval is 5 minutes;
Nagios is running and the next check for X is scheduled to 11:48.
So, somebody change the timeperiod of service X to 11:50-23:00.
When the next check runs, time_is_valid will become FALSE because 11:48 is OUT of new timeperiod.
Prefered time is calculed to 11:53 and we run get_next_valid_time passing prefered_time, that returns 11:53.
The code below is self explained:
I propose to use
get_next_valid_time(current_time,&next_valid_time,svc->check_period_ptr);
not
I will do this patch against development release and send again to list.
-rm
