Patrick Kremer wrote:
> I am running 3.0rc2. I am trying to get the variable $HOSTNOTES$ to appear in notify-host-by-email
> This is the notify-host-by-email command definition that I changed. I added "Notes: $HOSTNOTES$\n\n" in the spot shown below:
> # 'notify-host-by-email' command definition
> define command{
> command_name notify-host-by-email
> command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nNotes: $HOSTNOTES$\n\nDate/Time: $LONGDATETIME$" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
> The host I'm testing with contains only the word: TEST in its notes field.
> define host{
> use generic-router-intrust
> host_name intrust-bob-ds1
> alias Intrust BOB T1
> address 66.243.142.155
> notes TEST
> statusmap_image switch.gd2
> hostgroups intrust-office
> This is the debug log output:
> [1201644173.199143] [032.2] [pid=30977] Raw Command: /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nNotes: $HOSTNOTES$\n\nDate/Time: $LONGDATETIME$" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
> [1201644173.199170] [032.2] [pid=30977] Processed Command: /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: PROBLEM\nHost: intrust-bob-ds1\nState: DOWN\nAddress: 66.243.142.155\nInfo: (Host Check Timed Out)\n\nNotes: TEST
> The problem is that the processed command gets truncated and a notification never gets sent. If I change the notify-host-by-email definition and replace $HOSTNOTES$ with another variable, $HOSTOUTPUT$ for instance, the debug log shows this:
> [1201644289.198269] [032.2] [pid=30977] Raw Command: /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nNotes: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
> [1201644289.198292] [032.2] [pid=30977] Processed Command: /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: PROBLEM\nHost: intrust-bob-ds1\nState: DOWN\nAddress: 66.243.142.155\nInfo: (Host Check Timed Out)\n\nNotes: (Host Check Timed Out)\n\nDate/Time: Tue Jan 29 16:04:49 CST 2008" | /usr/bin/mailx -s "** PROBLEM Host Alert: intrust-bob-ds1 is DOWN **" [email protected]
> The notification gets sent successfully because the processed command is not truncated.
> I know I have the syntax correct because I have it working with other variables - it just wont work when I plug in the variable that I want: $HOSTNOTES$. It is listed as allowed in host notifications in the docs.
I tested the $HOSTNOTES$ macro, and it seems to work fine for me in
notifications. I don't think anything related to this was changed in
CVS since rc2, but I could be wrong. Could you checkout the latest CVS
code and see if the problem remains?
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
