Re: [Nagios-devel] Improving the host logic
On Fri, 16 Dec 2005, Andreas Ericsson wrote:
>> Are you serious? You consider this the Right Thing (TM) compared to having
>> the ability of defining the layer2 and layer 3 parent for each device?
> Yes. Most problems I've seen with VLANs doesn't so much have to do with the
> management network or physical device being down, but rather that one or more
> interface either breaks or go out of tune for one reason or another. Checking
> the management interface in such cases only catch a few of the possible
> errors.
We are not talking about whether pinging the management interface will
catch every "switch problem" (although I would say it does in 50% of the
cases).
You said and I quote "Give the switch an IP in each network and make it
switch2-vlan23", suggesting this as a solution to the parent logic
limitations, here you are discussing check_command logic which is totally
unrelated. That being said if the layer2 and layer3 parent relationships
were in place it is simply a matter of defining services that check for
more important criteria than just pinging the management IP. For example
checking to see if the switch port in question is inactive, failed or if
the switches VLAN exists/is in a fault state.
> Since you asked: I've used HP, Nortel, Extreme, D-Link, Cisco, Netgear,
> Zyxel, TekComm (don't use those), 3Com and Linksys.
> All of those, with the exception of TekComm, supported multiple IP-addresses.
> All of them also had the option of only serving tcp and udp-based services on
> one IP only.
Interesting, as far as I know up until recently Cisco switches were
limited to sc0. Also I note that you have changed tunes from saying its
possible to assign an IP addresses on every switch for each vlan to
saying they support "multiple" IP address, which some do and some don't.
In either case such an approach is silly at best.
> I have no influence what so ever what code gets in and what doesn't. I
> doubt if Ethan will write the code for this though, so if you want it
> in you should start hacking right about now.
Did not mean to imply you did. I appreciate your opinion on what Ethan
will find interesting and worth while. I wish I were more proficient at
C but I am not, my programming skills are limited to relatively
simple python programs for the most part. It may be possible for funding
to be obtained for a feature like this however.
>> Every inter-network device has at least one layer 2 connection and at least
>> one layer3 interface.
> A straight answer, if you please; Do you intend for host-objects to support
> the three configuration directives "parents", "l2parents" and "l3parents"?
I see no reason why l3parents wouldn't function exactly as parents
functions today, at least from a user perspective. That being the case
only two parent directives would need to exist. For those who do not
want to define l2parents they would only need to define the l3parent
directive maintaining existing functionality. Also I see no reason why the
"parents" directive could not remain as an alias to l3parents.
Cheers,
Shane
