Re: [Nagios-devel] Database access via Nagios
I appreciate the corrections and apologize for my mis-statements about
merlin architecture. . We are basing some work we are doinbg with
distributed Nagios on Merlin so it is very encouraging to hear about
your work on making the schema more scalable. I will definitely check
out that white paper and will recommend it to my teammates as well.
Max
On 3/18/10, Andreas Ericsson wrote:
> On 03/16/2010 07:04 PM, Max wrote:
>> Ninja reads Nagios information from the database tables created by
>> Merlin, which has both a NEB module and a daemon (merlind) that reads
>> from / writes to the NEB module.
> A partial truth. Ninja also uses the data stored by reports-module.
> Reports-module will be made redundant and its features incorporated
> into Merlin at a later stage, but since the reports-module is very
> widely tested we've decided to forgo including this feature in
> Merlin for the time being.
>> The Merlin database schema is very similar to the NDO database schema
>> with the addition of some fields to allow for multiple merlin daemons
>> to write to a single database (TBD - currently the daemons all use the
>> same hardcoded instance ID in the DB).
> This isn't true at all though. Merlin's object storage model is a lot
> simpler than that of [ni]doutils. We made it that way since this made
> it possible to write simpler and much more efficient queries for it,
> with the added bonus of being a lot easier to understand.
> Some basic testing showed that the ndoutils schema did not scale
> linearly with the number of objects monitored. Merlin's schema does.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
