Suggestion: Core Configuration Manager - With Checked
Post by Box293 »
Sometimes I want to disable a bunch of services, hosts, groups ...
It would be good to be able to select multiple items and then use the "With Checked" action to make them Active / Not Active.
Currently I need to modify each object and untick the Active box ... time consuming.
Nagios XI 2009R1.4 running on a VMware VM on an ESXi 4.1 host.
rdedon
Re: Suggestion: Core Configuration Manager - With Checked
Post by rdedon »
Good time saving idea, going through each box can be slow and tedious.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
