Re: [Nagios-devel] Timeline for NEB API documentation
Thibault GENESSAY wrote:
> I also know that the 3rd release of nagios will be focused on the
> engine, and not the CGI nor the data storage, so the NEB API is likely
> to be slightly modified, so it can explain why nobody wants to write
> docs that will be deprecated soon.
I'm not sure the neb api will change significantly in next release. The
current basic functionality (registering for callbacks, receiving
callbacks) seems sound and will most likely remain.
> So my actual questions are:
> - is a NEB api doc going to be released for Nagios 2 ?
Maybe, if someone takes the time to write it, but it's not very likely
because of the following reason.
> - if not, is a guru wanting to write a small paper (even 10 lines are
> better than nothing :) and post it instead of the "coming soon" link on
> the web site ?
The neb-api is designed for programmers and programmers only. While the
hello_world.c module is a fairly stupid one, it proves the basic
functionality. I saw another module somewhere, called sampler.c, which
was much more useful and should be able to give you whatever hints you need.
> - should I [kludge nagios-db/write a crappy neb] and forget about the
> rest ?
Whatever floats your boat, really.
OP5 AB www.op5.se
Lead Developer
