Re: [Nagios-devel] High latencies problem.
Can you provide a link to the code?
Brad
On Thu, 19 Feb 2009 19:12:24 -0800
"D. Emmanuel Feinsmith" wrote:
> Another note on this, the event broker that I am referring to can
> both buffer results in memory (to queue them up until Nagios is
> ready), and it can also queue them up in a dynamically sized Sqlite
> database, which also removes the command pipe size limitation. I have
> seen it handle 50,000 to 75,000 service check results on a dual CPU
> box with 4g RAM without any problem or significant latency issues.
> These kind of results were the basis for my earlier statement that
> the fundamental internal code of nagios is pretty fast, you just need
> to find quick ways to get the data in.
> Once nagios has captured the raw host and service check results,
> it's pretty efficient, even in the 2.x codeline.
> Daniel.
> On Feb 19, 2009, at 5:18 PM, D. Emmanuel Feinsmith wrote:
> > I have implemented an open source Nagios Event Broker which is a
> > multi-threaded Event Broker written in C which replaces NSCA and
> > inserts the service/host check results directly into the internal
> > nagios check result queue, completely bypassing the command pipe
> > and the command pipe reader thread. It also allows you to do
> > remote command execution and a bunch of other things.
> > Daniel.
> > On Feb 19, 2009, at 3:05 PM, Paul Fitzpatrick wrote:
> >> I am also using the command pipe to submit passive service checks
> >> via nsca to a master nagios host which does notifications and
> >> runs event handlers. I am also interested in knowing what is
> >> the alternative to the command pipe referred-to by Daniel.
> >> On Thu, Feb 19, 2009 at 1:51 AM,
> >> wrote:
> >> Could someone light me about how to use something else than
> >> command pipe to
> >> improve performance?
> >> On Tue, 17 Feb 2009 08:32:32 -0800, "D. Emmanuel Feinsmith"
> >> wrote:
> >> > Alessandro,
> >> Its inefficiency primarily arises when it needs to either
> >> > receive passive checks (through the command pipe bottleneck)
> >> > The key to nagios scalability and latency reduction is to educe
> >> the #
> >> > of fork/exec's to the smallest amount possible and keep away
> >> > from
> >> the
> >> > command pipe as much as you can if you are passive-check heavy.
> >> > Daniel.
> >> Open Source Business Conference (OSBC), March 24-25, 2009, San
> >> Francisco, CA
> >> -OSBC tackles the biggest issue in open source: Open Sourcing the
> >> Enterprise
> >> -Strategies to boost innovation and cut costs with open source
> >> participation
> >> -Receive a $600 discount off the registration fee with the source
> >> code: SFAD
> >> http://p.sf.net/sfu/XcvMzF8H
> >> _______________________________________________
> >> Nagios-devel mailing list
> >> [email protected]
> >> https://lists.sourceforge.net/lists/lis ... gios-devel
> >> Francisco, CA
> >> Enterprise
> >> participation
> >> code: SFAD
> >> http://p.sf.net/sfu/XcvMzF8H___________ ... __________
> >> [email protected]
> > Francisco, CA
...[email truncated]...
