> > i'm still having problems with ndoutils under Solaris 9.
> > =20
> > When i'm activating it (event_broker_options=3D-1) in nagios.cfg
> > my nagios won't start anymore !! it always stops with a=20
> segmentation fault!
> > =20
> > here's the traceback of the dump:
> > =20
> > (gdb) bt
> > #0 0xff1b3288 in strlen () from /usr/lib/libc.so.1
> > #1 0xff10bcbc in ndo_escape_buffer (buffer=3DCannot access=20
> memory at address 0x44
> > ) at io.c:424
> > #2 0xff104788 in ndomod_write_object_config=20
> (config_type=3D1) at ndomod.c:3183
> > #3 0xff103d30 in ndomod_write_config (config_type=3D1) at=20
> ndomod.c:2999
> > #4 0xff103b44 in ndomod_broker_data (event_type=3D7,=20
> data=3D0xffbef954) at ndomod.c:2940
> > #5 0x0001d038 in neb_make_callbacks ()
> > #6 0x0001ca38 in broker_program_state ()
> > #7 0x0001b67c in main ()
> >=20
> > is there anyone who could shed a little lite on this ??
> > =20
>=20
> Not really. The program receives a SIGSEGV in=20
> ndo_escape_buffer because it gets
> passed an invalid pointer (memory address 0x44 is not=20
> available to programs).
>=20
> Why it gets passed a bogus address on Solaris is a mystery to me, as
> contact_struct->name is located at relative address 0 within=20
> the contact_struct
> data structure (unless your compiler re-arranges it ofcourse).
>=20
Hello Andreas,
that's real funny.... i tried yesterday the same sources on a RHEL 4
system and it works perfectly !
and also funny is that the SIGSEGV on Solaris 8 is there whether i
compile Nagios and NDO with gcc (4.1.2) or Sun-Studio 11 ...
isn't there anyone who also has Nagios running on Solaris 8 ??
christian
